1985 Ford Bronco Wont Start
KYCOUNTRYBOY90
  • 1985 FORD BRONCO
  • V8
  • 4WD
  • 200,000 MILES
My 85 Bronco will not start. The only thing that happens when I turn the ignition is that the starter will whine. This is the third starter that I have put on it the other two the brackets broke. I have tried to turn the motor by hand to see if it will catch a different spot on the flywheel but it doesn't. The flywheel is not damaged. I have also tried to jump the solenoid but still nothing.
Friday, January 4th, 2008 AT 5:52 PM
BLACKOP555
  • 10,371 POSTS
So your saying it sounds like trying to start a car after its already started? Sounds to me that the pinion on the starter is not engaging and you should examine it.
Friday, January 4th, 2008 AT 7:54 PM
GHOST640409
Try taking a bushing between the oilpan and starter
Sunday, January 20th, 2019 AT 11:54 AM
