1985 Ford Bronco Truck stopped, now not starting,....fuel p
225,000 MILES • V8 • 4WD • AUTOMATIC
BLUESTRAVELER
The truck was driving and just stopped, I replaced the ignition module because it worked before....stab in the dark.
Replaced the high pressure fuel pump, no luck.... I'm not getting any fuel to the cylinders.
Question, does the fuel inertia switch reset once you start cranking the engine,...if so, is it then the in-tank pump? or do you have another suggestion?
Mar 5, 2010 at 10:08 AM
MERLIN2021
  • 17,250 POSTS
Inertia switch only trips during a collision. Reseting is not automatic, the red button must be pushed down, Did you check for spark? The ignition switch could be defective, Or the fuel pump relay, or the PCM power relay, those are in the under hood power distribution center.
Mar 6, 2010 at 9:25 AM
