1995 Ford Aerostar What Oil
1995 FORD AEROSTAR
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
1GREENHORNET
My 1995 Ford Aerostar has noisy lifters. What oil should be used in this situation. Will a certain weight tend to help lessen the noise.
Other than the noise, it runs good.
Thanks,
Jun 16, 2009 at 7:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You will want to use a little thicker oil. If you have 5 w 30 right now , maybe try some 10 w 40. Also using engine honey once every 6 months will help tighten your seals up to prevent them from stretching and burning up oil.
Jun 16, 2009 at 9:02 AM
