1996 Ford Aerostar timing belt
1996 FORD AEROSTAR
13,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAN KEPPLE
How do I adjust timing belt when it has slipped?
Sep 8, 2010 at 3:17 PM
LARRY6354
  • 20 POSTS
Heya, first off your timmimg belt will never have slipped. It is possible although not very that you have jumped a couple of teeth. If it has jumped more than two your vehicle would not run at all. it's probably not a timmimg belt problem as they either slip BIG TIME and stop the motor or normally break all together. What are your symptons . Get back w/ me. Larry
Oct 1, 2010 at 6:56 PM
