1993 Ford Aerostar Blown head gasket
1993 FORD AEROSTAR
129,465 MILES • 6 CYL • 4WD • AUTOMATIC
LUVBUNY
I was told by a mechanic That i have a blown head gasket How can i tell. I dont have any white smoke no oil in the water no water in the oil... It had over heated a couple of times when the weather went over 90 least summer and then it hapend again this summer a couple days ago
Jul 17, 2010 at 8:50 AM
RICHZOMBIE
  • 173 POSTS
Typical symptoms of a blown headgasket MAY include: -bubbles of air coming up into your radiator (remove cap before starting) -leaking radiator -milkshake colored oil -overheating -rough running -coolant or oil running from head -spark plug(s) that have a green tint (if green coolant). -white colored or sweet smelling exhaust. I emphasize "may" include one or more of these symptoms. If your thermostat and fan are working properly and you are not low on coolant, but you are overheating, then the mechanic was probably right.
Jul 17, 2010 at 9:10 AM
