1993 Ford Aerostar
PEAFISHNUT99
  • 1993 FORD AEROSTAR
  • 6 CYL
  • 4WD
  • 144,802 MILES
The van will start but cuts off with in 10 sec. If we unplug the mass air flow sensor it runs ok but will stall at stop lights. The comp check does not offer any codes we have tried everything help
updated:
the scanner code came back snap throttle we have done a tune up and checked wires
Saturday, September 26th, 2009 AT 3:15 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Would you post all the things you have tried? Also how where codes read OBDI scanner or analog volt meter?
Let me know
Thanks for donate
Saturday, September 26th, 2009 AT 3:37 PM
DOCFIXIT
  • 18,828 POSTS
Most likely the crank sensor when MAF unpluged it runs gives conflicting input to PCM.click on reply or I won,t get message
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_153.jpg
Monday, September 28th, 2009 AT 12:15 PM
