Engine Cranks Wont Start
GLORIA ANN
Joe,
No the Van does not start with starting fluid in cold weather. It is a cold weather issue. The Van always starts in temps above 25 degrees.
My husband said he knows where the crank sensor is
and if it is dirty or loose then one would think why would it work when the outside temperature rises above 25 degrees?
Just so you know- we use dry gas in winter months
in all of our vehicles.
So the next question would be does cold weather affect the crank sensor?
Gloria
Sunday, May 24th, 2020 AT 1:38 PM (Merged)
  • 109,885 POSTS
THe temp can affect many things. I need you to check to see if there is spark when the engine doesn't start. We need to determine that is the problem. If it doesn't start with starting fluid, chances are there is no spark.
SSBEN1
  • 1991 FORD AEROSTAR
  • 6 CYL
  • AWD
  • 13,178 MILES
When u try to start vehicle it blows the fuse link that comes off the selenoid Ineed a schematic for wiring the selenoid
SSBEN1
SSBEN1
[/quote:2318589503]
KENTZ71
  • 4 CYL
  • FWD
  • 150,000 MILES
I checked the reset button on the right side panelboard, wasnt tripped but I cut wires and by passed still will try to start but wont run acts like its starving for gas help this is my guys work van
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You will have to get the actual fuel pressure reading check, we must know if you have fuel pressure and good flow before going any further with a diagnosis.
Mark (mhpautos)
