2000 Ford Ranger High Idle
YATYAS
i have a 2000 ford ranger xlt 2x4 3.0 with a five speed manual. my question is sometimes when im driving and i push in the clutch the idle speed stays pegged as if i was going 40 miles an hour. sometimes I will be just pulling up to a light and the idle will just keep idling way above normal, then after awhile it will drop back to normal. This vehicle has 70000 miles on it, do you know what it could be?
Jun 5, 2007 at 5:26 PM
SERVICE WRITER
  • 9,123 POSTS
May be a carbon build up issue. Possibly in the throttle body at the plate or carbon build up in the iac motor. no check engine light? have codes been checked?
Jun 6, 2007 at 12:19 AM
YATYAS
there is no check engine light . I have not done any checks on any codes. how would you recomend to clean the throttle body and/or iac motor?
Jun 6, 2007 at 6:18 PM
SERVICE WRITER
  • 9,123 POSTS
Suggested Repair
Clean carbon buildup from the throttle body bore and plate and from the idle air control (IAC) motor. Scan for codes even though the check engine light is off.
Conversation Summary
A 2000 Ford Ranger with a 3.0 and five-speed manual sometimes holds a very high idle after the clutch is pressed or when stopping, then returns to normal. There is no check engine light and codes have not been checked. The expert suggested carbon buildup at the throttle plate or in the IAC motor and pointed to cleaning procedures for the throttle bore and IAC.
