The auto parts guy did you wrong, I work at advance auto, if the check engine light is on, then we can test for codes, since its a 1990 vehicle and not 96 or above your system runs off of a global obd1 and not obd2, if the light is on at time of test, you will get codes, next get a transmission filter kit perferabally PRO-KING, drain flush and add new to ALL fluids. When or if the test codes read, it may be an oxygen sensor, probally upstream. Good luck
SPONSORED LINKS
Thursday, September 28th, 2006 AT 11:59 AM
