I read that if one takes off the vacuum to the fuel pressure regulator and it leaks gasoline, then the diaphram is broken in the pressure regulator. Since mine did, I am replacing it as we speak. While I'm there I will check out the possibility of a leaking injector.
As I disassembled the car, I found that the area surrounding the injector nearest the drivers' is dirty. Probably not from a leaking injector, but just being an older car. Otherwise the injectors looked fine.
Also the check engine light has never came on, as of yet. I will get back to you if the problem still persists after changing the fuel pressure regulator, and injector seals.
Sunday, December 24th, 2006 AT 4:04 AM
