2016 Ford F-150 Crank Sensor Location Fix
150,000 MILES • 2.7L • V6 • TURBO • 2WD • AUTOMATIC
OBOY2010
I can't seem to locate the crankshaft position sensor on my 2016 f150 2.7L ecoboost engine. There's tons of literature and videos for the 3.5 but not for the 2.7 and they are not the same. Can anyone tell me, with certainty, where this sensor is located? I have the replacement in hand ready to go. Thanks in advance
Nov 21, 2025 at 5:06 PM
KRAKENAUTO
  • 114 POSTS
Ur is behind the right hand fender splash shield. Removal and Installation instructions are below. Photos attached as well.
Removal
NOTE: Removal steps in this procedure may contain installation details.
Remove the RH fender splash shield.
Refer to: Fender Splash Shield (501-02 Front End Body Panels, Removal and Installation).
Disconnect the CKP sensor electrical connector.
Remove the retainer and CKP sensor.
Torque: 10 Nm
Installation
To install, reverse the removal procedure.
Using the scan tool, perform the Misfire Monitor Neutral Profile Correction procedure, following the on-screen instructions.
Nov 22, 2025 at 9:43 AM
  • 55,837 POSTS
Nice work KRAKENAUTO :)
Nov 23, 2025 at 1:39 AM
Suggested Repair
The crankshaft position sensor is behind the right-hand fender splash shield. Remove the RH splash shield, disconnect the sensor connector, and remove the retainer and sensor (install torque 10 Nm). Reverse the steps to install, then use a scan tool to perform the Misfire Monitor Neutral Profile Correction procedure.
Conversation Summary
The owner of a 2016 Ford F-150 2.7 EcoBoost could not find the crankshaft position sensor and noted that 3.5L guidance does not apply. An expert said it is behind the right-hand fender splash shield and outlined removal, 10 Nm installation torque, and a required scan-tool misfire monitor relearn.
