Engine will not start after replacing head gasket
97,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
DICKO5721
I checked the battery (12.5v) when turning the key it just makes a loud click, when keeping the key turned it continues to click. Is this the starter motor?
Oct 27, 2019 at 11:51 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Chances are if the starter was good prior to the repairs, it still is. When you get a click, that usually indicates a weak battery. Can you have a helper turn the key to start while you check how much of a voltage drop there is with the battery? You need approximately 9.6v while cranking for everything to work properly.
Next, a loose terminal can do the same thing. Recheck battery terminals to make sure they are clean and tight. Also, check the main ground between the battery and engine block to confirm nothing was damaged.
Let me know what you find.
Oct 28, 2019 at 1:19 PM
DICKO5721
Good morning,
Yes, I tested the battery while cranking it over and the volts went down to 6.54. now as an additional question when I held the key on smoke came from the back of the starter motor. is that normal when held on?
Tom
Oct 28, 2019 at 9:57 PM
  • 110,248 POSTS
Welcome back:
No that isn't normal. First, make sure the engine can be turned by hand. If it can, replace the starter. It is getting power, so either there is a short internally or something has caused the engine to lock and the starter can't turn it.
Oct 29, 2019 at 2:21 PM
