Cylinder head gasket
88,146 MILES • 1.4L • 2WD • MANUAL
KERRI19775
Garage has said cylinder head gasket is showing signs of wear as pressure in radiator has dropping a little. would it be a good ideas to used steel seal to repair the gasket? or better to replace it? does steel seal work or do more damage?
Nov 2, 2016 at 9:58 PM
HMAC300
  • 48,601 POSTS
first we have no information on this car you cold use the sealer to try to repair it sometimes they work other times not. I prefer copper seal seems to do a better job. steel seal sometimes can clog heater, but just follow instructions.
Nov 2, 2016 at 11:06 PM
