Engine not starting properly
62,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
OLEG SALAFONOV
Turn on key action doesn't turn on check engine light and car cannot start. To activate check engine light (possible ECM) I have to depress and release brake pedal several times and/or shift transmission stick from P position and back. When I get check engine light on car starts perfectly without any problems.
Aug 27, 2021 at 1:57 AM
  • 110,244 POSTS
Based on the description, it sounds like a weak connection. Have you checked to make sure the battery terminals are both clean and tight?
Take a look through this link:
Let me know what you find.
Aug 27, 2021 at 4:00 PM
