1992 Mazda 929 Will not start.
SYLVSHOLL
  • 1992 MAZDA 929
  • 6 CYL
  • 70,000 MILES
I have a Madza 929 with 70,000 miles on it. The car had sat for time and was not driven. When I bought the car I replace the time belt first off, then I had to replace two Hydraulic Lash Adjusters in the right side of the motor. After carefully disassembling and labeling each parts I reasemble the head putting all parts back into their place. Line up all the timimg marks. Tried to chank the car it would crank up and cut back off if you tried to crank it again it the car would flood out. I went back into the car to check the timing it seem to be alright I even asked a high school class mate of mind that work as a mechanic for the Madza dealer ship for a number of years to look at it. And he said the car was in time. He suggested that I change the fuel pump relay connector in the relay box. I did that and tried to crank the car agin it crank up cut back off. Other items I chance Battery new, Battery cables in good condition. Distributor Cap, Fuel Filter, Wireset, Spark Plugs all new. Starter, Alternator rebuild. Fuel Filter new, Throttle Sensor new. EGR Valve checked I even preform the flashlight test on the EGR Valve and I could not see the light. I've also replace the water temperature sensor in the intake and the one by the heater inside the car. I've also check the firing order a number time and it is correct according to my alldata computer program. The rotor is also new as well. Need some help bad.
Wednesday, November 18th, 2009 AT 11:52 AM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR,Never heard of the flashlight test...use a vacuum pump and check pintle movment and release. then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
Wednesday, November 18th, 2009 AT 2:16 PM
SYLVSHOLL
  • 6 POSTS
Thank you for the information but I was wouder you said something about the filters. I've change the air and fuel filters. Could my problem still be the fuel filter I change it before I started driving the car. And there was some aout a half tank of gas in there could the settlement in the bottom of the tank have choke up the fuel filter already?
Wednesday, November 18th, 2009 AT 6:05 PM
MERLIN2021
  • 17,250 POSTS
If it's been changed recently, I doubt it. Go with the info in the two videos, and the stuck egr, is your check engine light on?
Thursday, November 19th, 2009 AT 2:31 AM
SYLVSHOLL
  • 6 POSTS
Wednesday, December 2nd, 2009 AT 6:01 AM
