Eagle Vision Stalls When Underside Gets Wet
BARTONM
My truck trys to stall or actually stalls when I get sprayed under the engine. What are the causes for this?
Mar 13, 2006 at 10:21 AM
RAYHUT
  • 134 POSTS
i don't know what your getting at with being sprayed under the engine. but if your saying if you go across a creek or something i understand.it your distributer getting wet it will make your vehicle stall.
Mar 13, 2006 at 10:21 PM
Suggested Repair
If water is reaching under the engine, check the distributor for moisture. A wet distributor can cause the engine to stall; dry it and keep water off it.
Conversation Summary
The owner reports an Eagle Vision tries to stall or stalls when sprayed under the engine and asks for causes. The expert says that if water is reaching under the engine, such as when crossing a creek, a wet distributor can make the vehicle stall.
