1993 Eagle Vision Won't Accelerate
A little back ground info if needed. It had the transmission seals replaced very recently had a new fuel filter and quick connect(becasue it broke cousing to leak fuel) The transmission fluid is clean oil clean.
how old is the filter?
It sounds like a transmission slipping issue. It is odd it happened right after a seal reapir however, wrong fluid used? Ironic timing? Can try a transmission filter and see. May need a tranny?
Basically. You start it up and drive for about 40-50 feet then it seems as though the power is not being transfered fully to the wheels. It just doesn't want to go once you get to about 25-30 mph. It will maintain speed but very slow to speed up. Plenty of power but it doesn't want to go faster. you come to a stop and start to go again and it barely speeds up. Takes about 200 feet to get to 15-20 mph. I tried to drive it in 3rd and it worked at first but then not so much. It will reverse just fine. Any time you park it and turn it off then back on it will do the same. All fluid levels are fine. Idle is fine. Rpms fine. Sort of gives the feeling of being in a high gear when taking off but if it were stuck in a high gear it would have no problem going faster than 30-35.
My first thought was the transmission but it seems to shift gears fine. I'm thinking it may be a drive line type problem or torque converter. But I know almost nothing about cars.
Any advise or help you can give is highly appreciated. Thank you for your time and effort.
I'm still inclined to think there is a transmisision problem, maybe torque converter but same general thing. Again, the transmisison filter MAY, take car of it, may not. Sounds like it's slipping and if continued, it will need a trany.
No clue. He just said a tranny sensor.
No idea on the tranny sensor in relation to the problem.
I have seen the wrong fluid used that causes a slipping as well. I believe the eagle may require ATF+3 fluid, but not positive.
I am have people tell me it sounds like a catalitic converter problem or fuel pump. The car gets plenty of fuel so I am think Cat. Conv. or maybe a driveline problem.
Tranny shop says it sounds exhaust related.
How low did the fluid get leading up to the other seals being replaced. Often I see transmisssions get irreversible damage from fluid running low. Symptoms and problems sometimes do not surface for another few months of driving.
I would like to think they know better about putting in the right fluid, but I have seen it done my guys who either don't know better, don't care or don't believe it.
I know others have said stuff about the fluid, but are you sure you checked it correctly? some cars including some eagles have to be checked a certain way, mine has to be put into drive then reverse then neutral with the engine running and warmed up before you can check it
Suggested Repair
Recheck the transmission fluid level using the correct warm, engine-running procedure and confirm the proper ATF type, likely ATF+3. A transmission filter service may help, but the symptoms point to transmission slipping or a torque converter problem that may require transmission repair, especially if fluid was low before the recent seal work.
Conversation Summary
A 1993 Eagle Vision drives a short distance, then barely accelerates while engine speed rises, although reverse works and fluid levels appear normal. Recent transmission seal work and a fuel filter replacement were noted. The expert suspected transmission slipping, possibly from low or incorrect fluid or a torque converter issue, rather than a catalytic converter, and advised verifying the fluid and considering a filter service or transmission repair.
