My truck trys to stall or actually stalls when I get sprayed under the engine. What are the causes for this?
Mar 13, 2006 at 10:21 AM
If water is reaching under the engine, check the distributor for moisture. A wet distributor can cause the engine to stall; dry it and keep water off it.
The owner reports an Eagle Vision tries to stall or stalls when sprayed under the engine and asks for causes. The expert says that if water is reaching under the engine, such as when crossing a creek, a wet distributor can make the vehicle stall.
