Eagle Vison intermittent staring problem
EAGLE VISION
SAFETY HARBOR
3.3 93 with 97K
When hot and parked, after short time wont start, turns over, found it had no spark. Waited 30 min, started perfectly.Does not do this every day. Changed spark plugs, cam sensor, coil, crank sensor. Now its worse than ever, if I get it started it is running on 3 or 4 badly, try feathering accel and it back fires with big flat spot. Starts with a miss, does not develop, sound like it is flooded or has 2 wet plugs, but if I can keep it running , nothing clears out. Feed the accel gently and it gets to 1500rpm with the missing and occasional backfire through inlet, like timing was out and dead plugs. Next change I have a fuel filter. Where should I be looking? Before I changed the sensors at least it started and ran fine, once it did start. Now very depressing. Should I just go fishing or start drinking? Or both?
May 19, 2007 at 4:03 AM
2CARPRO JACK
  • 11,533 POSTS
Be sure the plug wires are on the correct terminals on the coil.Check engine light on? If so have it scanned and get back to me with the code/codes
May 20, 2007 at 12:59 AM
SAFETY HARBOR
R e traced my steps, The cam sensor has an o ring half way up its perimeter so that it seals in the vertical hole. It mounts with a slotted tab and a 10mm bolt. I undid the bolt and applied downward pressure to the top of the new sensor, it moved down a cats wisker befor it bottomed out, re installed the bolt , turned the key, and "Rock and Roll".
Conclusion, sensors poorly made/designed require maximum insertion before correct tollerance is achieved, and a micron makes a difference.
May 20, 2007 at 4:27 AM
2CARPRO JACK
  • 11,533 POSTS
Glad to hear its fixed
May 21, 2007 at 12:45 AM
RWILSON881
I have a 93 TSI Visionwith 179k. had the computer replaced, no joy. Can you tell me where I can get info on replacing or adjusted this CAM Sensor. Is it a diy job?
thanks
Oct 13, 2007 at 5:09 AM
2CARPRO JACK
  • 11,533 POSTS
https://www.2carpros.com/kpages/auto_repair_manuals.htm
yes it is DIY
Oct 15, 2007 at 1:33 AM
RWILSON881
Thahks for the help. I finally replaced the cam sensor. It was way too easy to do. :-)
I now have a oil light that comes on when the car is hot and is idling if I rev the engine the light goes out. It has plenty of oil but it does seem to still be running hot but not by the quage. A friend believes I may have a bad oil pump or sensor. I guess I want to know how do I find out which it is.
Dec 15, 2007 at 5:16 AM
2CARPRO JACK
  • 11,533 POSTS
Install a manual gauge and see if it has oil pressure when hot.If it does, odds are good the sender is bad
Dec 16, 2007 at 12:25 AM
RWILSON881
A friend who is a mechanic says that the sensor or the pump not supplying enough oil could also cause the same symptoms. The car would stop because the computer would sense no oil. Sound plausible to me.
What about u?
thanks for the quick reply
Dec 16, 2007 at 2:45 AM
2CARPRO JACK
  • 11,533 POSTS
Only if the PCM is wired into the oil sender, not sure that they did that on these cars, GM did it, not sure about Dodge.If the car stops due to lack of oil it is usually a more permanent thing than just restarting it
Dec 16, 2007 at 11:13 PM
