1994 Eagle Vision Cooling Fan Will Not Run
BIGBOBMAL
  • 12 POSTS
1994 eagle vision tsi 174,000 miles engine cooling fan does not run replaced engine temp switch still no power but if i unplug the temp switch it ran but now does not.
Mar 26, 2006 at 12:09 PM
RAYHUT
  • 134 POSTS
you should have a inline fuse coming from your cooling fan find it and see if it's blown if it is then all you have to do is splice it.
Mar 27, 2006 at 3:50 AM
Suggested Repair
Locate the inline fuse on the cooling fan circuit and check whether it is blown. If it is blown, splice in a replacement.
Conversation Summary
The owner of a 1994 Eagle Vision TSI with 174,000 miles reports the engine cooling fan does not run. The engine temperature switch was replaced and there is still no power. Unplugging the temperature switch previously made the fan run, but it no longer does. The expert advises finding the inline fuse for the cooling fan, checking if it is blown, and splicing it if so.
