Will not start
150,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
STEPHEN BUFFA
This van is an E-250. installed rebuilt transmission, hooked up battery van will not start. No codes.engine turns over has spark but no fuel. Engine ran fine when disconnected. Checked fuse, inertia switch. Any idea's where to look next would be helpful?
Dec 19, 2017 at 8:53 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
There are actually three fuses. I assume you know about fuse #13 in the battery junction block (BJB), but the other half of that fuel pump relay is fed from a PCM power relay and that relay has two fuses, a #21 in the BJB and a #8 in the central junction block (CJB).
Dec 19, 2017 at 10:00 PM
STEPHEN BUFFA
All fuses are good in both fuse boxes.
Dec 20, 2017 at 2:34 AM
STEPHEN BUFFA
Still no fuel.
Dec 20, 2017 at 2:59 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
What about them relays?
Dec 20, 2017 at 5:36 AM
