Will not start after removing drive shaft
186,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
STEPHLEW87
The drive shaft went out. I had the truck in neutral to release pressure on the drive shaft while removing it. I was able to remove it without any problems, but I lost all power to the inside cab and now it will not start. I cannot put it into park nor apply four wheel drive. I reinserted the drive shaft in attempt to put it into park but still no power and cannot shift into park. Any suggestions?
Jan 10, 2019 at 4:49 AM
Good afternoon,
It sounds like you have a dead battery. Did you check the battery voltage?
If you have a voltmeter do the checks to be sure you have 12.6 volts.
Start there.
Jan 10, 2019 at 5:34 AM
STEPHLEW87
The battery was full and it started with no problem less than ten minutes prior to me pulling the drive shaft.
Jan 10, 2019 at 6:18 AM
You need to check it now. Check the voltage with a volt meter.
Jan 10, 2019 at 6:20 AM
