1992 Dodge Van
TODD BARTLETT
  • 1992 DODGE VAN
Engine Performance problem
1992 Dodge Van 6 cyl Two Wheel Drive Automatic
it starts and idels fine but when put in gear it sputters and has no power it sputters like not getting gas
Saturday, July 17th, 2010 AT 1:22 AM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Saturday, July 17th, 2010 AT 2:05 AM
