Lack of acceleration, chugging, hesitating, bogging, misfiring etc. Could be caused by one of the following below:
We start here-inspect and test all the items below and comeback with the result.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
SPONSORED LINKS
Sunday, August 8th, 2010 AT 3:30 AM
