2003 Dodge Truck getting code p0700
158,000 MILES • 6 CYL • 4WD • AUTOMATIC
KRSMITH10
My transmission is not shifting out of first gear properly and after it does shift it will not shift again. I got a fault code p0700. Will a lock up overdrive solenoid fix my problem?
Aug 31, 2009 at 12:19 PM
  • 110,248 POSTS
Many times the P0700 is a internal problom on the TCM. However, before replacing the TCM, check the ground to the transmission. A poor or bad ground will give this code. Also, check your EATX fuse and relay,
Also before replacing the TCM, after checking ground, clear the codes out, and re check it.
Often, after there is a ground or power problem the TCM will hold old codes. Remember it is very common to find a ground problom. You can make a ground wire from the battery to the transmission using a at least a 14 gage wire. This will provide a good solid ground.
Let me know if this helps.
Oct 7, 2009 at 5:05 AM
