1996 Dodge Truck Starting Problems
JIMBEAUX69
  • 1996 DODGE TRUCK
Engine Performance problem
1996 Dodge Truck V8 Four Wheel Drive Automatic >10000 miles
Was having a problem with a squeaky pully, replaced alternator. Now the truck wont start. It will turn over and will start when I pour gas past the butterflies, then dies out. I pulled the ASD and fuel relays and switched them out with the starter relay that I know is good but it still wont start. I replaced the fuel pump less than 50,000 miles ago so I hope it isnt that. Any ideas of where to start checking?
Saturday, January 10th, 2009 AT 4:29 PM
  • 109,755 POSTS
Ifit's starting with manually giving it fuel, the pump musn't be working. You will need to see if there is power to the fuel pump. Also, before that, have you checked fuel pump pressure?
Wednesday, January 21st, 2009 AT 4:06 PM
