HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Truck
Engine
Symptoms
Not Running
1996 Dodge Diesel wont start
ORVAL
MEMBER
1996 DODGE TRUCK
I have a 1996 Dodge Diesel 3500 2wd and it would start ok but here the other day it will crank over but will not start at all.
Tuesday, August 21st, 2007 AT 1:53 PM
PUNCH01
MEMBER
"check the fuel shut off solenoid. This controles the valve that feeds fuel to high pressure pump onthe drivers side of engine. Possible bad wire"
Thursday, August 30th, 2007 AT 9:14 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1996 Dodge Truck Runs Fine Dies Wont Start For 30...
First It Started With Driving Down The Road Rpms Shoot To 0 The Truck Dies When Trying To Restart It Turns Over And Sounds Like It Is Going...
Asked by
318girl
1996
DODGE TRUCK
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1996 Dodge Truck No Start
Veh Was Running Fine, Then After Being Shutoff It Would Not Start Again, There Is No Fire From The Coil And No Codes, Could This Be The...
Asked by
jody tanner
1996
DODGE TRUCK
1996 Dodge Truck Wont Start Not Sure Were To Look...
1996 Dodge Truck V8 Two Wheel Drive Automatic 225xxx Miles I Was Running Errands On Luch Break And As Soon As I Pulled Out Of The Bank...
Asked by
slayer6112
1 ANSWER
1996
DODGE TRUCK
My Truck Has Been Running Fine But Last Week The...
My Truck Has Been Running Fine But Last Week The Starter Stuck On And I Had To Unhook The Battery To Stop It, When I Hooked It Back Up The...
Asked by
mjstolllivecom
1996
DODGE TRUCK
Crank And No Start. Pulled Transmission And Now Won't...
I Had My Truck In The Shop And I Pulled The Transmission Because I Had Clutch Problems. Put The Transmission Back In And Found That My Cps (...
Asked by
Shredder1212o
1 IMAGE
1993
DODGE TRUCK
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
