1996 Dodge Truck no start
JODY TANNER
  • 1996 DODGE TRUCK
  • V8
  • 4WD
  • 29,000 MILES
Veh was running fine, then after being shutoff it would not start again, there is no fire from the coil and no codes, could this be the ignition module? I forced a code [tps] and the computer triggered p0123, so I dont think its a computer
Sunday, August 10th, 2008 AT 1:00 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors-
Check for power at the coil dark green and orange wire.
Sunday, August 10th, 2008 AT 4:08 PM
JODY TANNER
Thank you! There is only power to the green and orange wire when you first turn on the key, also there are no cam or crank sensor codes. I tried a new coil, so maybe pickup coil or ign module? Do you know of a test for these components?
Sunday, August 10th, 2008 AT 5:01 PM
Measure the resistance of the pick up coil as per the repair manual-also check the air gap-ignition module-I recommend you get an Actron3 ignition module and engine sensor tester
Monday, August 11th, 2008 AT 1:06 AM
