1999 Dodge Stratus leakage
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
PATTY STANLEY
The front passenger floor became soaking wet with an odor, this happened overnight. No rain, no window leaks. What would cause this?
Jan 5, 2008 at 12:42 PM
  • 31,937 POSTS
Hi there,
Have the cooling system pressure tested with the heater turned on. this will check for a leak in the heater core, part from this the only other place is the A/C drain tube could be blocked (if fitted)
Mark (mhpautos)
Jan 5, 2008 at 12:53 PM
