1999 Dodge Stratus No Shift or Speedo
SCIPIOB13
1999 Dodge Stratus, 160K miles, 2.4L automatic.
While driving, my speedometer stopped working and after stopping for an intersection, the car wouldn't shift into the high gears. I tried to limp it in, but then the AC stopped working and almost immediately I noticed a lot of grey smoke coming out. I stopped, popped the hood and smelled an almost burning-electronics type of smell. I noticed the smoke seemed to come from the AC and there was oil spewed out around there. A mechanic said the AC compressor was definitely shot but didn't know why the speedometer and tranny would be affected. Are these all parts of the same problem or are they separate, coincidental problems? Thanks for the help.
Aug 7, 2007 at 5:35 PM
2CARPRO JACK
  • 11,533 POSTS
Differnt problems. Teh trans sounds like the VSS (vehicle Speed Sensor) quit working.The a/c needs to have a little 134a put in it to see where the leak is.
Aug 8, 2007 at 12:52 AM
SCIPIOB13
Thanks! The AC compressor was totaled and has been replaced. I've taken it to the transmission mechanic and informed him of your suggestion about the VSS problem.
Aug 8, 2007 at 4:44 PM
Suggested Repair
Treat the issues as separate. Check or replace the vehicle speed sensor for the dead speedometer and failure to shift into high gears. The AC compressor was already replaced; if a leak remains, add a small amount of R-134a to locate it.
Conversation Summary
A 1999 Dodge Stratus lost its speedometer, would not shift into high gears, then lost AC and smoked with an electronics smell and oil around the compressor. The expert said these are different problems: the transmission and speedometer point to a failed vehicle speed sensor, while the AC needs a small charge of R-134a to find the leak. The owner later reported the compressor was replaced and the transmission shop was told about the VSS suggestion.
