The front passenger floor became soaking wet with an odor, this happened overnight. No rain, no window leaks. What would cause this?
Jan 5, 2008 at 12:42 PM
✓Experienced Mechanic
Hi there,
Have the cooling system pressure tested with the heater turned on. this will check for a leak in the heater core, part from this the only other place is the A/C drain tube could be blocked (if fitted)
