1992 Dodge Stealth White Exhaust Smoke
WARRIORAZ2007
I just recently bought myself a 1992 dodge stealth. it has a dohc 24v v6 engone and has 130000 miles. i was wondering if anyone had any idea about what could be causing the problem im having. sometime when im driving i notice white smoke coming from the exhaust. it usually happens more when im at a stop light and i accelerate. Does anyone have any advice??? anything will help!!! Thanks.
Mar 21, 2007 at 4:38 PM
  • 75,988 POSTS
Temperature gauge is it getting higher than normal. You sounded as though you're leaking coolant in the combustion chamber which can be caused by a blown headgasket.
Mar 21, 2007 at 5:37 PM
Suggested Repair
Check whether the temperature gauge runs higher than normal and look for coolant loss. White smoke when accelerating can indicate coolant entering the combustion chamber, often from a blown head gasket.
Conversation Summary
The owner of a 1992 Dodge Stealth with a DOHC 24-valve V6 and 130,000 miles reports white smoke from the exhaust, especially when accelerating from a stop. The expert asks if the temperature gauge runs high and suggests coolant may be leaking into the combustion chamber from a blown head gasket.
