Transmission problems 1990 spirit
1990 DODGE SPIRIT
JUAN JOSE
Good day
Hope someone could help me on this one, I have a 1990 spirit, that only work on second gear, never shift to the next gear, does not shift, starts in second and keep it all the way, I only have two gears, second and reverse.
Took the car to the transmission workshop, and they said that the transmission module is failing, I change the module but the car still has no shifting.
the car did sit for 1 year
my question is what can I do to fix my car?
Dodge Spirit LE
year 1990
Engine V6 3.0 Mitsubishi
mileage 75588 miles
Automatic Transmission Just rebuilt 2 weeks ago for the same problem
Thanks in advance for your help
Juan Jose Moreno
Cabo San Lucas, BCS (Baja)
Mexico
May 26, 2007 at 9:56 AM
E40WATER12
  • 522 POSTS
I have one question, What kind of tranys fluid did they use? I can tell you if they used ATF mecron III fluid isnt the proper kind of tranny fluid, ATF +3 is what needs to be inside that tranny, The ATF+3 costs a little bit more money, Dodge products is picky,
May 27, 2007 at 4:56 PM
JUAN JOSE
Thanks for your time, I will change the oil for the one you recomend, and see what happens
I will let you know after oil change
Jun 2, 2007 at 10:26 AM
