1991 Dodge Spirit Stalls and Won't Restart
PALMIROS
  • 7 POSTS
Hey there, I have a problem regarding my Dodge Spirit 1991 - 176 000 KMS, 2.5L.
The problem first occured a few months ago, when it first stalled, I was going about 60-70kms. It just stalled, for no apparent reason, the Check Engine light flashed, and i waited a few hours for it to restart.(i then checked for spark, which it had, and also checked i had enough gas). Since then, this problem seems to occur more and more often, the periods of time, which i have to wait before it starts, vary anywhere between 3 minutes to several hours. I have noticed, it seems to stall more often if i turn the heat on, or if i idle(sometimes even if i just put the key in the ignition switch, without turning the engine on) The simptoms, in all cases listed above, include (the odomoter(by which i mean turation of the engine RPM) will just rocket to 6/7 come back down go back up and so on, this with the engine off) *The check engine light flashes, SOMETIMES Check Gages is on as well*
Now, I decided enough was enough and took it to a mechanic, and it just so happened it stalled while in the parking lot. He tried to turn it on, saw the problem occur, and suggested the problem is coming from the [b:5329454fa4]Catalystic Converter[/b:5329454fa4], also pointing out that the lack of reaction (slow acceleartion is coming from the same faulty CAT(I have read tons of post where the answer to problems was given by : Faulty Gas Pump/Filter). The problem in this case is not that there is not enough gas going through, i think there is too much gas and it clogs. Of course, they also recommended an O2 sensor to go with the Catalystic Converter. I have an appointment tomorrow morning at 9oclock, and was wondering if anyone had any ideas/experiences with this kind of problem, and what your suggestions, or recommandations to me would be, before i go drop a few hundred dollars.
Anything would be appreciated. Thank you.
*note, car stalls often, not always*
*it doesn't necessarely stall at stop signs, as i have read in other posts*
*not influenced by speed or touration as far as I know*
*there is spark*
Your help would be GREATLY appreciated. :cry:
Jan 20, 2006 at 6:55 PM
  • 55,682 POSTS
1. Tap the catalytic converter and listen for rattling inside, sometimes a piece of the cat can get caught in the outlet pipe and stall the car.
2. Check fuel pressure, ignition spark and isolate which system is failing.
:D
Jan 21, 2006 at 3:25 AM
PALMIROS
  • 7 POSTS
[quote:e8de8c6034="2CarPro Ken"]1. Tap the catalytic converter and listen for rattling inside, sometimes a piece of the cat can get caught in the outlet pipe and stall the car.
:D[/quote:e8de8c6034]
The deed has been done. I`ve taken it in, I`m picking it up in about 30 minutes. I`ll let you know how it turned out.
By the way, I`m getting the CAT and O2 sensor changed. Hope that does the trick :S
Jan 21, 2006 at 3:29 AM
PALMIROS
  • 7 POSTS
Just got back home. Everything went as planned..
Catalytic Converter changed.
O2 Sensor changed.
Seems to be working fine, i`m guessing that might have been the problem..
Thanks.
Jan 21, 2006 at 6:52 AM
PALMIROS
  • 7 POSTS
**Problems re-ocurring.
I`m thinking it might be something from the GAS(PUMP). ANY IDEAS?
Feb 1, 2006 at 5:49 PM
Suggested Repair
Tap the catalytic converter and listen for internal rattling that could block the outlet and stall the engine. Check fuel pressure and ignition spark, then isolate which system is failing.
Conversation Summary
A 1991 Dodge Spirit 2.5L with about 176,000 km stalls at random, sometimes with the heat on or while idling, and may not restart for minutes to hours. The check engine light flashes, and the tachometer can sweep with the engine off. A mechanic suspected the catalytic converter and oxygen sensor. An expert advised listening for a rattling converter and checking fuel pressure and spark to isolate the failing system. Those parts were replaced and the car seemed fine, but the stalling later returned and the owner suspected the fuel pump. No further expert diagnosis was given.
