wont start
DCOPELAND32
I have a 2001 Dodge Ram 1500 5.2 liter 2 wheel drive automatic truck with 98,000 miles.I was backing my trail into the garage turned the truck off. Went to restart the truck and it wont even crank over. When you turn the key all the lights come on but wont crank over.Ive checked the starter,neutrual safety switch and still wont start. Can it be the ignition switch or any other ideas.
Jun 11, 2007 at 12:26 PM
RDW223
I have the same problem...let me know when you get an answer
Aug 8, 2007 at 3:13 AM
DPWD23
  • 136 POSTS
It could likely be the ignition switch. Their is also a chance the ignition fuse has blown. Check all fueses that could potentially cause the issue, and all connections at the starter and battery.
Aug 10, 2007 at 11:05 AM
