1991 Dodge Ram Cranks No Start
DON SPRINGBERG
1991 Dodge Ram 150 1/2 ton 4 w/d 318 engine
Truck will roll over but won't start. :evil: Think it could be spark, but not sure. Could be the coil.. How can i check?
Thanks for your time, I appreciate it. :P
Apr 2, 2007 at 12:04 PM
  • 75,988 POSTS
[quote:3dd1948ebd="Don Springberg"]1991 Dodge Ram 150 1/2 ton 4 w/d 318 engine
Thanks for your time, I appreciate it. :P[/quote:3dd1948ebd]
When you're thinking then you're not sure-its like saying maybe -disconnect a plug wire and ground it,crank it over and check for a snapping blue spark then report back your findings and willingness to stay with us all the way till its fix.
You came here for help its all up to you.
Apr 2, 2007 at 11:26 PM
Suggested Repair
Disconnect a spark plug wire, ground it, and crank the engine while checking for a strong snapping blue spark to see whether the ignition or coil is producing spark.
Conversation Summary
The owner of a 1991 Dodge Ram 150 with a 318 engine says the truck cranks but will not start and suspects a spark or coil problem. The expert advises grounding a plug wire, cranking the engine, and checking for a snapping blue spark before reporting the result.
