2012 Dodge Ram P2175 Low Airflow
TOYLANDER1
snap on scanner....mitchell on demand.... im not getting anywhere with this. what is it, or at least what is the abreviation TAC any help at all would be awesome
Aug 13, 2007 at 11:03 AM
DPWD23
  • 136 POSTS
Throttle Actuator Control (TAC) System
P2175-LOW AIRFLOW/RESTRICTION DETECTED (SLOW ACCUMULATION)
When Monitored: Ignition on and no MAP Sensor or TP Sensor DTC present.
Set Condition: MAP Sensor has failed in one of four ways based on the Gas Flow
Adaptation value being too low. One trip fault. Three good trips to turn off the MIL. ETC
light will flash.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
RESTRICTED AIR INLET SYSTEM
RESISTANCE IN THE (F856) 5-VOLT SUPPLY CIRCUIT
RESISTANCE BETWEEN GROUND AND THE (F856) 5-VOLT SUPPLY CIRCUIT
MAP SENSOR
RESISTANCE IN THE (K1) MAP SIGNAL CIRCUIT
RESISTANCE BETWEEN GROUND AND THE (K1) MAP SIGNAL CIRCUIT
RESISTANCE IN (K900) SENSOR GROUND CIRCUIT
TP SENSOR OPERATION
RESISTANCE IN THE (F855) 5-VOLT SUPPLY CIRCUIT
RESISTANCE BETWEEN GROUND AND THE (F855) 5-VOLT SUPPLY CIRCUIT
TP SENSOR
RESISTANCE IN THE TP SENSOR SIGNAL CIRCUIT
RESISTANCE BETWEEN GROUND AND THE TP SENSOR SIGNAL CIRCUIT
RESISTANCE IN THE (K922) SENSOR RETURN CIRCUIT
Aug 17, 2007 at 7:18 PM
Suggested Repair
Treat P2175 as a Throttle Actuator Control low-airflow fault. Check for a restricted air inlet, then test the MAP and throttle position sensors and their 5-volt supply, signal, and ground circuits for resistance or shorts to ground.
Conversation Summary
The owner of a 2012 Dodge Ram asked what TAC means after a scanner showed P2175 low airflow. The expert identified TAC as Throttle Actuator Control and explained that the code can set when gas-flow adaptation is too low, with possible causes including a restricted air inlet, MAP or throttle position sensor faults, and resistance in related supply, signal, or ground circuits.
