2001 Ram 5.9L engine light, alot of info on the truck
XRTDX8
  • 2001 ALL OTHER MAKES ALL OTHER MODELS
2001 1500 Ram 5.9L gas engine
Problem is that when i'm on the highway traveling 60+MPH, alot of times my engine light will come on and blink, some times the truck will start to shake(like the road is bumpy) the shake will go away if I increase the RPM's sometimes it comes back once the RPM's go steady sometimes the shake won't come back for awhile. The engine light will turn off if I let of the gas for a little while. Sometimes the engine light will come on if I get into the gas real hard but other times when i'm just cruising along. Never comes on unless i'm on the highway. Also I can here a very distinct metalic tinking sound my guess is its a peice of metal in front of the catalytic converter from when I got it changed, but i'm not positve.
What I have instaled on the truck is:
MSD 6A ignition
MSD blaster coil
MSD plug wires
Ram air hood
High flow magnaflow catalytic converter
Flowmaster exhaust
I don't know if one of these things has to do with this problem, I kinda did everything together so its hard to pin point if this problem started after one of these things were installed.
I hooked a computer up the truck to try and read the engine code, the code wasn't in there unless the light was on, it was hard to drive 70mph and work a computer at the same time, but I manage to get something about cylinder 5 misfire, but the truck never seemed like it misfired. Also when I had the computer hooked up I checked out the O2 sensors, the sensor - B1S1 the fuel trim% jumps anywhere inbetween -5.46 & 4.68, but the O2 sensor - B1S2 the fuel trim% is a steady 99.06. The voltage on both sensor change around but are different at the same time.
Any help would be much appreciated. I plan on doing some long distacne traveling soon, but don't want to take my truck with this current conditon
THANKS
Tuesday, February 27th, 2007 AT 5:49 PM
CHEVY22
  • 1,375 POSTS
The engien light is probably the misfire code, possibly a bad wire or plug, track down that misfire code first and go from there and let us know could be the ignition box also
thanks, jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Wednesday, February 28th, 2007 AT 2:59 PM
XRTDX8
I checked the wire it seems to be ok, I disconnected the MSD ignition and I didn't seem to have a problem tonight, going to do a few more test drives down the highway. Then i'm goin to hook it back up and see if the problem comes back and go from there.
Thanks for the info
Wednesday, February 28th, 2007 AT 5:54 PM
Related Check Engine Light Content
Is it Safe to Drive Check Engine Light?
VIDEO
