1976 Dodge Ram Hot Load Knock
Check the ignition timing and EGR
You sure its not overheating-did you check the EGR it will cause detonation if its not opening-Knock sensor not retarding the timing
If the insulator is split or chipped, detonation (spark knock) may be occurring in the engine. The underlying cause here might be an inoperative EGR valve, overadvanced ignition timing, excessive compression due to accumulated deposits in the combustion chamber, or engine overheating.
Do a wet and dry compression test and comeback with the results-if its higher than normal you got accumulated deposits in the combustion chamber-raising the compression to a point creating detonation
Pre-ignition and detonation is two different things
Suggested Repair
Confirm ignition timing and that the engine is not overheating. Check whether an EGR valve is present and opening, and whether a knock sensor is failing to retard timing. Perform wet and dry compression tests; higher-than-normal compression points to combustion-chamber deposits causing detonation.
Conversation Summary
A 1976 Dodge pickup with a 318 engine develops severe rattle under load only after reaching full operating temperature, and it is worse in hot weather. Higher-octane fuel and different plugs did not help, and the owner says timing is correct. The expert identifies spark knock or detonation and recommends checking timing, EGR operation, overheating, knock-sensor timing retard, and wet and dry compression for deposit-related high compression. The owner plans to check and report results.
