2004 Dodge Ram Whirring Noise
FRANKOG
I have a 2004 Dodge Ram 2500 8' bed club cab pickup 5.7l 4x4 with 54000mi. after I accelerate past 15-20 mph I begin to hear a whirring noise which is fairly constant in pitch, but may decrease in volume slightly when under load. I checked each of the wheel bearings, and all appear to be fine. I checked the U joints which also appear fine. I did notice that the truck has a split drive shaft, and there is what appears to be a rubber guide near the rear of the cab that is worn. could this be the cause of the whirring. any ideas appreciated. Thanks,
Frank
May 31, 2007 at 3:16 AM
E40WATER12
  • 522 POSTS
Is that the rubber boot that covers the U joints on the drive shafts?. I would try to grease the U joints, I would got those Rubber boots around the shaft,replaced as well, Also youre noise could be window moulds seperating.
Good Luck.
Jun 2, 2007 at 1:06 PM
Suggested Repair
Grease the driveshaft U-joints and replace the worn rubber boots or guide on the split driveshaft. Also check whether separating window moldings could be causing the noise.
Conversation Summary
The owner of a 2004 Dodge Ram 2500 reports a fairly constant whirring noise after accelerating past 15-20 mph. Wheel bearings and U-joints appeared fine, but a rubber guide on the split driveshaft near the rear of the cab was worn. The expert suggested greasing the U-joints, replacing the rubber boots, and checking for separating window moldings.
