1994 Dodge Ram 1500 A/C Stops Under Load
CHRYSLER
PAYNEDE
I have a 1994 Dodge Ram 1500 5.2L with 155,000 miles. When the truck is under a load such as passing or climbing a hill the A/C with not blow air out of vents on the dash. Fan is still running but air is blocked for some reason. Is this a vacuum problem?
May 10, 2007 at 4:56 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, check for cracks or breaks in the vacuum feed. If the truck doesnt have a vacuum resevoir, you might want to invest in one, they are very inexpensive and stop the problem
May 10, 2007 at 8:20 AM
Suggested Repair
Check the vacuum feed for cracks or breaks. If the truck has no vacuum reservoir, install an inexpensive one to prevent loss of airflow under load.
Conversation Summary
The owner of a 1994 Dodge Ram 1500 5.2L reports that under load, such as passing or climbing a hill, the A/C fan still runs but no air comes from the dash vents, and asks if vacuum is the cause. The expert confirms a vacuum problem, advises checking the vacuum feed for cracks or breaks, and recommends adding a vacuum reservoir if the truck does not have one.
