hvac
CHRYSLER
1991 VERT
hello, i have a 1991 lebaron convertible, 3.0 v6, 146,855 miles. heat is not coming out of the heater ducts. it worked fine last night. it's coming up through the defrost. no matter what button i push it still comes out the defrost. when my mom had the car the defrost quit working. defrost works fine for me though, so did the other functions.(defrost, heat, vent etc.) i'm thinking the hvac unit itself might need to be replaced. maybe not sending the right signal to route properly? thanks for your help.
Apr 6, 2006 at 4:46 AM
1991 VERT
since these "car pros" have never answered any of my questions, i found out for myself what the problem was. there is a vacuum line that comes off the brake power booster that goes through the fire wall to the hvac unit. this line was broken. stuck a small diameter vacuum hose to either end & fixed the problem. hope this helps someone else.
Apr 11, 2006 at 12:57 PM
