Update: I have traced the problem, I think, to the driver side (there are three) 32 pin connector to the computer, located in the heat above the engine. Wiggling indevidual wires does not seem to make any difference. If I push hard on the connector I can get the engine to work again. Could a curcuit board in the computer have a crack in it? It seems to solid a moumting for that to happen.
1999 Dodge Ram No-Start and No Bus
Any sugestions how I can keep it cooler. It is located in the engine compartment just above the engine. Not a proper place for electronics without proper shielding or cooling
No water coling ideas :P
Don't stick any reflective insulation to it. Although it seems like a good idea at first, it will also hold heat generated by the electronics inside and fry it faster.
IF it is behind a plastic panel, go ahead and stick a small piece of reflective mat to the plastic, but just enough to reflect radient heat away (under and on engine side). Last thing you want to do is create a heat trap that ends up making the area even hotter!
I'm sure you could fabricate a sheet metal heat shield for the bottom and side that is closest to the engine and stick the reflective mat on the engine side of that, to reflect the radiant heat away from it. space it an inch or three away from the ECM to allow for air flow to the surface of it. Any modifications like this would likely void the warranty, so it's best to leave it alone until it's no longer under warranty.
You could also rig a small 12 volt fan from radiohut to blow on it when the key is on. Position that so air from near the fender is blown on it, but at highway speeds enough air flows through there to blow anything away that's not bolted down.
Suggested Repair
Have a shop with a vehicle-specific scan tool identify which module is pulling down the bus. The instrument cluster connector is a common cause; unplugging it briefly often restores communication. The PCM was already replaced under warranty. Do not water-cool it or attach reflective insulation directly to it. After the warranty ends, a spaced sheet-metal heat shield or a small key-on fan may help, but modifications can void coverage.
Conversation Summary
A 1999 Dodge Ram 2500 van with a 5.2L V8 intermittently stalled or cranked without starting, with gauges at zero and a no bus message and no stored codes. The owner found that pressing the driver-side 32-pin PCM connector restored operation and suspected a cracked circuit board from engine heat. An expert recommended a vehicle-specific scan tool to find the bus component dragging the system down, noting the instrument cluster connector as the most common cause. The dealer replaced the computer under warranty. For cooling, the expert advised against water cooling or insulation stuck to the PCM, and suggested only a spaced heat shield or small fan after the warranty expires.
