Dodge Ram Passenger Floor Wet From A/C
It is dripping out the tube, but I'm still getting quite a bit of water inside the truck as well, coming from the same area. What now?
Thanks !
On option 2 above, can I blow air directly into the drain tube to remove clog or does the air need to come thru the intake? many thanks!
Suggested Repair
Locate the evaporator plenum where the A/C lines enter the firewall and clear the drain opening from below with a plastic tie wrap. If water still enters the passenger floor, remove the wiper cowl, find the grilled intake, and slowly flush the evaporator with evaporator-core wash with the fan on high, or blow compressed air up through the drain. Remove any cabin filter first.
Conversation Summary
A Dodge Ram owner reported a wet passenger floor between the seat and door and suspected a clogged A/C drain. The expert directed them to the drain hole where the evaporator plenum meets the firewall and advised clearing it with a plastic tie wrap. The owner found a horizontal drain that released water but the interior leak continued. The expert then recommended flushing the evaporator through the cowl air intake or blowing air up the drain to clear remaining debris.
