I would appreciate your help
Thanks :D
Return the truck to the shop that recently worked on the power steering lines and have them inspect the A/C system. A damaged refrigerant line can trigger the low-pressure cutout and keep the compressor from engaging. Inspect all refrigerant lines and components for damage or oil at a leak. For the whistling, note whether it occurs only on defrost or only with heat, then pinpoint the noise; a duct leak or debris in the ducting is possible.
The owner of a 2004 Dodge Ram 1500 5.7 Hemi reports that after a power steering pump tube repair, the A/C blower runs but the compressor will not engage. High heater speed also produces a whistling sound through the vents. The expert advises returning to the shop, checking refrigerant lines and components for damage or oil from a leak that would open the low-pressure cutout, and locating the whistle, which may be a duct leak or material inside the ducting.
