Ac bypass
200,000 MILES • 5.2L • V8 • 4WD • MANUAL
JOSH RAMEY
I took out the A/C compressor put a new alternator and serpentine belt and now even with a jump my truck will not start. It turns over but never actually starts. Any ideas?
May 9, 2017 at 11:57 AM
CARADIODOC
  • 34,413 POSTS
What have you checked so far?
May 9, 2017 at 11:58 AM
JOSH RAMEY
Put on the new bypass pulley and belt.The belt is put on right. Also put on a new alternator.
May 9, 2017 at 12:04 PM
JOSH RAMEY
No place to reconnect the two plugs that were on the old compressor could that keep the engine from starting?
May 9, 2017 at 12:06 PM
CARADIODOC
  • 34,413 POSTS
For a crank/no-start, you have to check for spark, fuel pressure, and injector pulses. If one of those is missing, that is the circuit that needs to be diagnosed. If all three are missing, there are two sensor circuits that need to be checked. You also need to read and record the diagnostic fault codes. Do you know how to do that yourself?
May 9, 2017 at 12:29 PM
RENEE L
  • 1,260 POSTS
Hi JOSH RAMEY,
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
May 10, 2017 at 8:47 AM
