Engine not idling and stalling?
91,000 MILES • V8 • 2WD • AUTOMATIC
OOLDMAN
I have a 04 ram 1500 5.7L. My truck won't start unless i press the gas pedal and hold the pedal down. once I let off the gas it shuts off. the engine shakes when it runs. the check engine light tells me that the O2 sensors are not reading right I replaced those. EGR valve is fine. I cleaned the throttle body. the truck will start if I remove the O2 sensors and will idle but RPM goes up and down. The exhast smells really lean to. I can hear the fuel pump start up.
Sep 10, 2009 at 5:21 AM
IMPALASS
  • 3,112 POSTS
Hello –
I would suggest taking a fuel pressure check to see what the output is. You may hear it but it may not be putting out enough pressure. This sounds like you have a vacuum leak, dirty throttle bore or the IAC motor is not working but to be sure lets check out these guides to help us fix it.
https://www.2carpros.com/articles/stall-at-idle
and
and
Sep 11, 2009 at 5:33 PM
OOLDMAN
There is pretty good fuel pressure I checked the spark plugs and they are black from running lean I checked all the plugs and there is no sign of a leak all are black. I was happy to use the guide and find a vacuum leak by the throttle body all fixed!
Sep 12, 2009 at 3:21 PM
IMPALASS
  • 3,112 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Sep 12, 2009 at 4:03 PM
DAVIDFLAKEJR
I get a code for incorrect barometric pressure???????
Jun 9, 2021 at 5:35 AM (Merged)
  • 110,248 POSTS
Chances are the MAF is the problem. However, I need the actual code number to be sure. If you can, send me the code.
DAVIDFLAKEJR
it was the map sensor, thx for ur help
JAYBJORDAN
I have a 2001 Dodge Ram with 99,000 miles with a manual transmission. It started cutting out and stalling. It would sometime be hard to start like it was not getting any gas after it stalled and sometimes would not hold an idle once it starts, but after a few minutes it would. I replaced the fuel pump and not much change. Sometimes it will start, but then it won't hold an idle. Then sometimes it won't start, like it's not getting any fuel. Sometimes it will be running fine, then when you let off the gas, it dies. It will usually start back up, but it may or may not hold an idle.
Jun 9, 2021 at 5:36 AM (Merged)
BUNDY
i have same vehicle that did the same. i changed the IAC valve and that solved it.
BUTCHCURRIER
How do I change my IAC (Idle air control valve)? I belive this is the fix since my problem started all at once. My truck was starting and running fine until this morning. I was driving and pulled into a gas station to get a cold drink and when I got back in my truck it would start and only stay running if I kept my RPM's up around 1500-1800. If I take my foot off the throttle, the engine will die.
There are No codes and my Check Engine ligh is Not on.
Jun 9, 2021 at 5:37 AM (Merged)
MERLIN2021
  • 17,250 POSTS
It's bolted to the throttlebody Fairly simple...You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! Any codes? Check engine light on?
NICKBOUDIN
My truck is now having the exact same problem. I've changed plugs, wires, cap, rotor, cat converter, fuel pump, egr valve, and pcv valve.
I cant seem to find if I have a leak. This post exactly describes my truck, and i'm completely stumped. A mechanic told me to drive the truck around, while the computer resets itself to my idle's speed. But I dont see how that's possible.
MERLIN2021
  • 17,250 POSTS
It's right at the top of the engine, where the butterfly of the throttle body is, it's held on with 2 screws and looks like this!
https://images.2carpros.com/forum/automotive_pictures/62217_IAC_4.jpg
BRETTPATTERSON21711
  • 10 POSTS
Cuts off when trying to idle can you help me please?
Jun 9, 2021 at 5:38 AM (Merged)
  • 75,988 POSTS
and
and
BRETTPATTERSON21711
  • 10 POSTS
No check engine light.
CARADIODOC
  • 34,412 POSTS
I suspect rasmataz could use a few more details. This can be a real common problem with a REAL easy fix, . . . if the battery was recently disconnected, but you have to elaborate on other observations and the recent history.
  • 75,988 POSTS
Yeap! ain't enough to fly to the moon-shoot at it on what will affect the idle speed, could be something simple-give more details
BRETTPATTERSON21711
  • 10 POSTS
Everything works fine, just got the truck so don't know much about it. Got a new muffler on it been driving it for about a month with no problem. I hit the cat just to see if it was stopped up or something and then it started right up and idled .
  • 75,988 POSTS
Thanks for coming back with the problem-Good Luck
MYRON PEAK
99 dodge ram will not idle. Recently [2 weeks ago]replaced fuel pump. Today replaced thermostat. Disconected the battery before replacing thermostat. Prior to replacing thermostat no problem ideling. Filled with fluid now starts but will not idle.
  • 75,988 POSTS
This sounds like the IAC valve is not working or needs to be cleaned here is a guide to help you get the problem fixed.
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
and check this guide as well
https://www.2carpros.com/articles/engine-stalls-idles-too-high-low-after-dead-or-replaced-battery
Cheers
BOOMER73
I had to replace the my IAC to fix the problem cost me $45.00 from Rock auto
JOZZY
my truck will start and then stall on some days and other days it will stay running just changed the idle control censer and the problem is still there looking for some help
CARADIODOC
  • 34,412 POSTS
If the battery was recently disconnected or run dead, the engine computer must relearn minimum throttle before it will know when it must be in charge of idle speed. To meet the conditions that will cause this to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals.
caradiodoc
BSODERSTROM
My truck is doing a number on me where i can start it but it will not idle. If i keep gas into it it runs strong. I had a guy tell me the fuel filter was in the tank, and it needed changed, then another guy told me i need a co2 sensor or a catalactic converter. I have no engine codes im not over heating i have no noises, my exhaust has a leak in front of the converter. Help
  • 110,248 POSTS
Chances are they are both wrong. If it runs good other than the at idle, the idle air control valve may be bad or you may have a vacuum leak. Because there is no check engine light makes it a guessing game. Start with the easy things first. Look for vacuum leaks and let me know what you find.
PS: A bad fuel filter would cause more problems under a load not an idle when the least of fuel is needed. As far as the O2 sensor, it could cause a problem. However, if the O2 sensor is the problem, it may be a result of the exhaust leak.
Jun 9, 2021 at 5:39 AM (Merged)
BLBOONE
i have a 1998 dodge ram 3500. when you start the truck in after it has set for a couple of hours the truck lopes for 5-10 min then dies. you have to keep starting the truck 10-20 times to befor it will not lope after you start it.
WRENCHTECH
  • 20,760 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
WIL ZILEN
What would cause it to shut off at an idle or running down the road it gives no codes replaced all sensors complete tune up new pcm new ignition switch?
CARADIODOC
  • 34,412 POSTS
What is involved in restarting the engine after it stalls? Do you have to wait a half hour for it to cool down? Will it always restart right away or do you have time to check for spark? Have you checked for loss of fuel pressure? That is not monitored by the Engine Computer and will not set a diagnostic fault code. This sounds like you have a vacuum leak, dirty throttle bore or the IAC motor is not working but to be sure lets check out these guides to help us fix it.
and
and
WIL ZILEN
today it stalled sprayed starting fluid down the intake and it made no differance
WIL ZILEN
i replaced the idle air control motor again it worked all fixed thank you.
CARADIODOC
  • 34,412 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
ANDYSDODGE
It starts fine but when gets to normal operating temp RPMs drop and I have to keep pressing on the accelerator to keep it idleing. I have replaced the fuel filter, fuel pump,throttle position sensor. Im at my wits end. Can you help? Thanks in advance.
ANDYSDODGE
Think I might have fixed my problem. after reading all the info here I replaced the idle air controller and PCV valve. Problem seems to be fixed. We will see.
GIANTKILLER
It will start but does not idle when brought to an idle.will not idle at all. Tried warming up but still no idle.
Jun 9, 2021 at 5:40 AM (Merged)
CARADIODOC
  • 34,412 POSTS
Are you saying the idle speed is too low and you have to hold your foot on the accelerator pedal to keep the engine running? If that is the case, this is a real common problem caused by disconnecting the battery or running it dead. The Engine Computer lost everything in memory. Most of that will be relearned on its own except for "minimum throttle", which takes a very specific set of conditions to relearn. To meet those conditions, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals. Until that is done, the computer won't know when it must be in control of idle speed.
This guide can help
GIANTKILLER
I found the igniter wire comming out of the fuse block to the starter had come apart. Simple splice fixed it.
  • 55,616 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
JOVANG
I purchase the truck from a University that was used to help students move. I purchased it after it has been sitting for five to six years. It fired up like a champ and drove strong however after it ran for a little bit it started stalling when it came to the idle position and would not start back up immediately (sometime it did most of the time it did not). I replaced the ignition switch and ignition coil it started up and ran all day like a champ. Problem came back after I put some fresh gas in it this time it would not start till the next day. I got it to start and dove it to the shop. I siphoned all the old gas that was sitting for those years (it was light brownish like malt liquor). After I siphoned it out I replace the fuel pump. It would crank but not fire back up. I replaced the distributor cap, rotor, and spark plugs. Would not fire back up. Note: before I purchased it I was told the camshaft sensor and O2 sensor had been replaced.
