2003 Dodge Ram AC's cold while driving, idling not so much
7,600 MILES • V8 • 2WD • AUTOMATIC
CJANKE1
My husbands Ram 1500 has started blowing warm/hot air while it's sitting in traffic or at a light. Basically idling. But while driving it is so cold that you freeze. I have to close the vents. What sould be causing this. I have taken the truck to a dodge dealership for another weird rpoblem like this & always get the same result. No solution & a wasted day. What could be causing this intermttent problem? Thanks
Aug 17, 2009 at 2:34 AM
2CARPRO JACK
  • 11,533 POSTS
If it has an expansion valve instead of a fixed orifice tube, the expansion block may be sticking occasionally causing no cold air.Be sure the fan clutch is good and pulling a good amount of air through the radiator/condensor when idling.Ideally having aset of gauges on it when it is acting up so that the pressures can be seen to help diangonse it
Aug 17, 2009 at 2:49 AM
CJANKE1
Well, thanks for you speedy reply. As i know nothing about what you said. ie the "expansion valve instead of a fixed orifice tube" I am mostly confused. But i am sure a true car mechanic can do what you said to check out. This gives me a little more to tell them than just, just not working right. I will print our your reply & have them check those things. So, thanks for your help.
Aug 17, 2009 at 3:04 AM
2CARPRO JACK
  • 11,533 POSTS
Sorry about that, yes a qualified tech will understand what I am talking about. The valve controls the temp and the fan makes air mover across the condensor making the pressures stay in range
Aug 17, 2009 at 3:43 AM
