Battery has a full charge and connections are all good? Did you check voltage circuits at the starter relay? Terminal 30 is hot all the time. My info showed terminal 86 goes hot with the key on. Terminal 85 is ground for coil side of relay. Terminal 87 carries voltage to starter solenoid, when relay is energized. I didn't think to look at any possible security system? Use a voltmeter to check fuse circuits and relay terminals.
SPONSORED LINKS
Sunday, May 16th, 2010 AT 1:36 PM
