2000 Dodge Ram engine will not start
180,000 MILES • V8 • 4WD • AUTOMATIC
JAKECAZANDER
engine would not start so i banged on the gas tank to rattle the fuel pump...ten it started so i figured i would change the fuel pump....i put a test light on the fuel pumps wiring harness while the tank and pump was out from under the truck...and the light would go on when i would turn the key...then i would turn the key off and try it again and it wouldnt turn on....anyway i installed the fuel pump and tank...truck started right away....went for a drive threw some fuel in the tank and it wouldnt re-start at the gas station...i think the fuel relay is ok...any suggestions??
Feb 25, 2010 at 3:55 AM
TOOOMANYTOYS
  • 513 POSTS
Try swapping fuel pump relay with another known good relay. If that doesnt work check the signal to the relay commanded by the pcm. If no command is going to relay when the trucks not running. It may need a pcm.
Feb 25, 2010 at 4:04 AM
JAKECAZANDER
thanks ! i will try that asap
Feb 25, 2010 at 5:09 PM
